MSD 6AL, PN 6420 The 6AL delivers everything the 6A does with the addition of a built-in Soft Touch Rev Control. This feature allows you to set an rpm limit to protect the engine from over-rev damage caused by driveline failure or missed shifts. Other MSD RPM Controls can be connected to the 6AL such as a Three Step Module Selector (PN 8737) or RPM Activated Switch (PN 8950). The 6AL also comes supplied with rubber shock mounts and 3,000, 6,000, 7,000 and 8,000 rpm modules.
Any one have one installed and what are your thoughts on the item. Do you like it. Does it make a big difference. You get a big power gain?
