I'm gonna change piston rings on my motor. It's 7M-GE, I hear the price difference between aftermarket ones, and Toyota factory ones, is huge. Should I spend more and get the Toyota ones? I wouldn't mind if you guys say so, but if the difference is like, from 50 thousand to 80 thousand miles, I wouldnt care, as it'd take me really long to run even half of that.
Anyways, while I'm doing so, I wanna buy a few things for my car. I think I will buy the K&N FPIK for the non-turbo, I've heard it's good. I already did a 2.5 custom exhaust. So it should improve everything altogether, right?
Ok, now to the MSD issue... I have some $30 cables that I want to change, they were just too cheap, heh. I'm thinking of buying the MSD 8.5mm cables from 935 too (along with the K&N FPIK). So, I have two questions:
1. What spark plugs should I get? Mines are not old at all, I changed them like 3 months ago. Does this really matter....? Should I get those iridium ones?
2. Is the MSD really worth it? It's over 200 dollars, and for all I know, what it does is make the spark plug discharge more than once, when the car is below 3,000 rpm. I assume above this RPM it has no effect, but since most of the time the engine is below this, if there is any improvement, it should be noticeable, right? Does it improve performance? Gas mileage? Or just "smoothens" the ride? ... I was thinking of this: http://935motorsports.com/catalog/product_info.php?cPath=79_14_40&products_id=198
In here http://www.msdignition.com/sci_6.htm it talks about it.
I don't know much about MSD's... How is it that the voltage sent to the spark plugs is 45,000 volts instead of the usual 28k or so? Is this thing that does it? Because I've heard the term "coil blaster" and it's got me confused. Please enlighten me, you wise ones
I was also thinking of those OBX headers....
Anyways, thanks in advance for any help
