mr2 ct26 vs. mk3 ct26
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hi, I can probablly get my hands on a ct26 from an mr2 and I'm wondering what are the differences between the two. Do you guys think it would work and work properly on a 7m? Would it be better or worse than stock? Thanks.
-Steve
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Doward said:
Smaller A/R exhaust housing, twin scroll inlet... that's as far as my limited knowledge takes me :)
Thats more than I knew. I guess it wouldn't work that well huh. Thanks for the reply. Keep em comin guys!
-Steve
ma70t
7mgte-s
Jun 7, 2005
141
va
supra ct26 is an upgrade for the mr2 and gt4 guys it dosent work to good for our 7m
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Same a/r exhaust housing.
Twin scroll inlet.
Twin wastegate door.
Same a/r compressor housing.
3 mounting holes for different wastegate actuator positions.
Same turbine.
Smaller compressor wheel.
Center bearing housing has a larger cooling chamber internally and no heat shield under turbine wheel.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
there are 2 variants of the 3SGTE CT26. well, 3 technically. there are 3 generations of the 3SGTE
1G; single scroll CT26, smaller exhaust AR, same turbine, smaller compressor, same cold housing
2G: twin scroll CT26, "larger" exhaust AR, same turbine, smaller compressor, same cold housing
3G: referred to as the CT20B, but not a real name used by toyota. thats about all i know.
I had pondered a Sequential 7M-based CT26, except using the 1G 3sgte hot sides for quicker spool on 1.5L exhaust volume. 600rwhp on pumpgas would be the heat!
Selz202
More than Regular Member
May 1, 2005
248
Black Diamond Wa
If i were to do something like that i would just use the stock 1j twins... but im not about to do something like that heh.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
looking at them side by side the exhaust side looks the same size but diffrent manifold port. supra has on round one and mr2 has two ovels. on the comppressure side its got a much larger turbine. thats all i know
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
the divided inlet MR2 turbo is the "Twin entry" twin scroll version from the 2nd gen MR2... yet again.
if you are desperate, you can get a regular T4, slot the bolt holes and itll bolt right up to the stock manifold. this is how SP makes bolt-on turbos.
