How long of bolts do you recommend I should buy? 1" longer than stock? 1 1/2" longer? I want to make sure my engine doesn't fall of the stand due to its weight. What kind/size bolts have you guys used? Thanks.
EDIT: I guess what I'm trying to ask is how far do the bolts thread into the engine. I would check but that means i have to pull alot of stuff from the garage to get the motor right now. I don't want to do that and put it all back because I'm going to the store for the bolts right afterward. Any help or advise?
