S
supranut
Guest
:drink1: Does anyone know if there is a solution or treatment that you can put on your used or new mouldings that will prevent them from rusting which causes the warping? I was thinking possibly a coating of urathene which may keep the moisture away from the metal backing on the moulding. There must be something that can be done. I understand that buying an 89 would be a solution but that's not in the budget. Thanks for any suggestions....TT :icon_conf
