motor oil is 5 months old.. should i change?
malloynx
NC
well my AMSoil is like 5 months old, but i only have like 2000 miles on it. the car sat for 3 month when i went to germany. should i change it out anyway?
mkIIIman089
Ohio
Amsoil reccomends 6 months I believe. Last oil change I did was at 6 months, so you've got another month in it. But if you would like to do it a bit early theres no harm I suppose.
Generally I go 6 months or 3k miles.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
I don't know if this link will lead you there, but this is the Amsoil recommended change intervals page from Amsoil.com
http://www.amsoil.com/lit/g1490.pdf
Also, when an engine sits for a while, moisture (condensation) gets in the crankcase and creates rust. I would go ahead and drive the car for a day or 2. This will allow the oil to collect loose particles and trap them into itself and the filter. Then change the oil and filter.
It sure wouldn't hurt to change the diff oil, and do a drain/refill on the trans too.
