motor mounts?!?!?!?
ma70mkiii
139
ohio
ok so today I was getting all ready for my swap to begin tomorrow when I got a shocker! The holes for my motor mounts don't line up to the holes!!!! I thought that the 89+ motor mounts would work with the 1jz or have I been had!? Plz someone help me. Yes they are the round style mount and they come out of my 89 ma71.
Tim
regular member
Oct 16, 2006
272
CA
the motor mounts will work, but the motor mount brackets are different.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
you sure the motor is as far back as it will go? When i did mine, turns out it was 2 inches forward of where it was supposed to be. I had to lift the back of the motor and swing it back into the holes.
NickSupra
179
tn
Ok, I was just hoping someone could clear this up for me.
mid 89 and previous need new mounts for a jz swap
mid 89 and later the 1jz will drop right in
Someone correct me if Im wrong so far.
So if I plan on dropping an aristo motor into my 91 I will definitely need either custom mounts(bic) or the 1jz mounts?
So i am guessing the aristo 2jz mounts are different from the 1j.
Basically the 2jz aristo mounts wont fit the mk3 period?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
square mounts, get adaptors, 90+ subframe or hack and weld the early subframe, circle mounts, good to go
AFAIK aristo mounts wont work, but jza70/80 mounts will
jmcboost
Missouri
Ya, you need to find the motor brackets that come off of a 1JZ that was mounted in a MK3 supra. Then you can use those brackets with the rubber mounts to install the engine in the 89+. Look in the 1J for sale. I bought a pair for $120.
jmcboost
Missouri
Actually It looks like there is a pair for sale in the 1JZ for sale section. You may want to see if they will work. Only $85!!!!!!
becauseican
Vancouver
www.bicperformance.com
The 89+ round mounts will work but NOT the 7M brackets, like said before you will need to find a set of JZA70 brackets or get the BIC replica brackets and use the round mounts with them. I have them instock and ready to ship, you will see them in about a week.
Randy@BIC
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i bought the bic solids actually today... my 7m were toast and my jz's weren't looking so hot either heh
strictlySupra
157
Canada
wth im confused...
ive been getting parts ready for my swap 2j into pre 89 mk3
i have the BIC mount adapters and the square mounts? is this going to work?
also still have the pre 89 crossmember
OneJArpus
2,798
^ to answer ur question, YES
I have the same setup 1J w/ BIC Brackets & 88 Mounts (SQ)
That is the main reason for BIC Brackets but some 89+ Use it cause they may have the wrong brackets on their 1j or it didn't come with any
