motor mount question
bowsercake
828
Irvine, Ca
Most likely they are worn out. My stock 90 had motor mounts that were cracked and busted up pretty good. I bought the 1998 MKIV Turbo mounts and cut off the extra aluminum nipple and they installed perfectly. They are encased in metal and better built. If you get a discount from the Dealerships on SF then the price i good.
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
Thanks guys.....I just went ahead and bought the solid ones from BIC....i know i will need to get used to the noises but it cant be worse than riding around on busted stock ones....Thanks again
