Well I just finished completing my 1JZ single turbo swap and I was hoping to fire the engine today. I pulled the efi fuse so I could prime the turbo with oil and I went to turn the motor over. At first it sounded ok and it cranked for about a second or less and then it just stopped. The engine stopped as if there was something in the way.
I then turned over the engine by hand and it was harder then usual and I hear a squeaking noise coming from the bell housing area. It went away after a few degress of turning the motor.
I then tried to turn the motor over again and sometimes it will turn over continuously and other times it will just stop.
Any idea what this could be? I pulled the starter motor and all seems fine and I inspected the flywheel. I am beginning to think something is binding in my clutch perhaps?
