Most unrealiable car
huntin5L
Niles, IL
Always something with this car i tell you. Can anyone tell me how i can get my damn passenger side window up. Neither switch will make it go up, but both switches will work when putting it down. ANy help would be much appreciated. Im stuck and it is pouring.
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
Try canned air first!!! Spay in the switch.. If no then hit the swith a couple times while pounding on the door it will go up slowly. Then change your switches.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Window lock.
Check the contacts. My drivers side passenger switch would not roll up the passenger window up. clean it.
And quit yo bitchin son. My passenger window isnt even in the tract. And I cant figure out how to get it back in
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i found some times that if you roll the window down, and the switch sticks, the motor gets hot, and you cant get the window to go back up.... unfotunaly you have to let the motor cool down before it will work again..
i would say quickly tarp that bitch, and pray the window motor's are still good.
i priced one and their like 250+ from toyota.
I had this happen many years back and it was a tired motor, only way to get it back up was to pull the trim and push it up by hand while hitting the up button.
I ended up pulling the motor and rebuilding it and it's been fine since.
huntin5L
Niles, IL
It was the contacts i got it working, what i did was take the white part of the switch out and shaved the burnt shit off the metal contacts and it works now. Hope this helps someone else, this is my second set. I wonder if i can do this to driver side switch for the passenger window
