Pics tonight!
So yeah, I dedicated this weekend to the Supra. This working MWF till 7pm, and T/Th till 9pm is leaving me *no* time to work on my car!
Things to fix this weekend:
Leaking transmission pan
Leaking rear transmission output shaft seal
Change Oil+Filter
Remove 198k mile stock exhaust
Install 3" elbow I got from Suse some time back (thanks again!!)
Install 3" single piece exhaust, from the elbow back.
Just doing some work on my baby
What the hell, I'm taking a break anyway
A Supra on jack stands? No way! Gotta be a hoax!
Here's why I started this - bastard leaking tranny pan!:
Changed it with a spare NA pan I had - notice the spots are not there for the magnets (though I did put the 4 into the pan):
Hell, while I'm at it... mightaswell (I get them pretty often ) - replace the rear tranny seal (had a small leak there) and change the oil - notice the oversized M-209 used :
I've always used 15w50, but with winter here, it's cooling off a little - so I'm going to see what my oil pressure looks like, with 10w30 (oil presure before was ~42 cold, ~15 warmed up, and ~35-40 cruise):
Screw it - this is SUPRA WEEKEND DAMMIT - AND MY 3" EXHAUST IS GOING IN! Good thing too, as you'll see in the next couple pics:
Stock DP:
Stock catback:
Wtf?? WHAT THE HELL? HOW THE HELL DO YOU INSTALL IT BACKWARDS??:
Damn good thing that I'm replacing the exhaust then. Hope that in 2 weeks, I'm doing better than a 17.8 when I hit the track again. This is the replacement:
And thanks to our resident Suprra_grl
Everything is complete, except I need to get a new nylon washer for the oil pan drain plug, and actually install the 3" exhaust system.
Oh yeah, and refill the fluids
Considering I'm doing 3" elbow, downpipe, AND catback all at once... I hope for a big boost in performance!
Change Oil+Filter
Stock DP:
Stock catback:
