I had my day off yesterday so I checked the hose coming off the bottom of the turbo, and it has a little crack just where the clamp is.
I checked the level of the power steering fluid and it was low so I added some and today I went to check and it's low again. The smell of the exhaust is kinda sweet. I saw some oil on the top of the manifold but probably was when the valve cover gaskets were bad. The gauge only reads 4psi.I have a hole in the stock muffler.
I didn't pass the smog check. There's a knock or ticking sound in my engine. I checked the antifreezer and it's fine no leaks, no oil leaks either. The turbo is new as well. I'm going to check the Air flow meter.The idle is high 900-800 rpms. It's hard to stars in the morning.
I bought a 3" cat back no cats/ 3" DP but I haven't recived them yet. Should i installed them ? probably it's going to help me if I have a clogged catalytic .
