As of right now I'm just looking for some more suggestions on what to check. I have an oil leak but I'm having trouble locating it. Someone suggested an exhaust cam seal so I haven't gotten to that just yet. The leak only seems to show up when I'm out driving the car, so at idle I can't get anything unless I've driven it around prior to checking.
I put in some of that leak finder that glows under a black light and drove it around to get the leak flowing. Well It seems to be hitting the fan and blowing onto anything in that general area. The collection is very heavy right under the p/s pump, but i am not losing tranny fliud it's all oil, the black light confirmed this. I was going to take the timing cover off to see if there was any oil behind it but as of now I am clueless as to where this leak is coming from.
I am going to do a rebuild in the summer but I'd like to have this problem out of the way for now. How likely is it that a hose or something else is spraying oil into the fan? I did replace the oil cooler lines before that is suggested so I'm still looking for more possibilities. I'll see if I can get a good pic with the florescent light but I don't know if it will show up clear enough.
