Yes.. If you don't want the power to drop off at high RPM, get rid of the CT-26 completely. Like the Dr said, the tiny CT-26 turbine side will choke the flow at high rpm no matter what compressor wheel you use. A simple bolt-on turbo like the SP61GT, Bossturbo or any other T4 turbo will allow the 7M to pull hard to redline.
