An update for anyone interested:
Spent most of the evening tightening the suspension up but went after a couple of the vacuum lines and the more important sensors.
Got them all either hooked up or plugged and decided to try to time it. Jumped the 2 connectors and fire it up, it was about 30 degrees retarded at first and backfired out the intake a couple times, I'm sure that was good for it.
Moved the CPS a tooth over and she roared to life, but is idling at about 1500. I shall look into that over the weekend. I'm guessing it is probably just a vacuum leak but who knows, could be TB or ISC or anything.
I gotta say though, the motor is smooth as silk and the exhaust sounds fantastic. I have the suprasport elbow, older AMS 3" downpipe, and my buddy and I welded up a 3" exhaust from straight pipe and a 180 degree mandrel bend. You guys seem responsible and all so you probably aren't in favor of a loud exhaust, but it's still quieter than the 454 Chevelle it's sitting next to.
One question I do have is what exactly the connector to the oil pressure sender looks like. I can't seem to find a clear picture of it anywhere and there are a couple connectors chopped off my harness that I need to repair.
