more boost!!
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
could cranking up the boost about 5psi:naughty: help keep me from running so rich? correct me if im wrong but i read somewhere on here that 1psi is close to 11hp is this right? or does anyone really know?
i gonna go from 10psi on the 1g to 15psi and see how much of a difference i can get.
jdub
Feb 10, 2006
10,730
Valley of the Sun
It may lean you out some, but you'll have 2 problems:
1) the ECU will sense the increased airflow and add fuel.
2) Unless you have a Lex AFM, you'll hit fuel cut at ~12 psi
Worth mentioning - if you start pushing a stock HG (especially the orginal one), you are asking for a BHG ::bhg::
Edit: Sorry bout that...didn't realize he had a 1G-GTE :3d_frown:
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
here's a better idea if you want a fast car.
if you convert the 1ggte to a big single, you'll only make around 250RWHP (with supporting mods)
and that' cost a Decent amount of money and custom work
Drop a 7mgte, with VERY little mods you can easily get 250rwhp
1ggte is a joke no offensive i wouldnt mind a 1ggte car if i bought it for cheap and used it as a DD
Long story short, you want power Cheap and easily, get a 7mgte
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
well i guess i'll see what happens i like my 1g it may be kinda under powered but if the turbos die i can get a big single. i wanna see what i can get out of the 2.0 for now.
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
The "little" 1g-gte used to be able to be upgraded to 2.5L It was made by hks iirc. Go single and I think youll get 300 horses with supporting equipment. I wish i could get a 1g-gte. Dont have big bux to spend.
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
Uhm ok
Could careless about a 1ggte.
the cost of the stroker kit must be expensive, might as well get a 7mgte
i know some fact's because i was wanting to build a 1ggte and let people know that small motor could get some balls, But gotta make custom everything, alls they sell for it is a Clutch, parts would be very hard to come by
so :D
or you could also put 1jz twins on it. turn up the boost..... but like i originally said, 7mgte=more power cheaper
sure you could make it fast, you can make anything fast with money, but if u want to save money get a better motor and more powerful... go with a damn 7mgte
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
why would anyone wanna swap to a 1g and if you want cheap easy power swap to a 1jz gte and do intake exhaust and boost controller and in lot of cases a large front mount, you'll break 300hp no problem and have a reliable and unique platform in the U.S. anyways.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
projectsupra said:
So you're using information from a friend of a friend? You don't have a 1G with a single turbo setup? I drive mine daily with a single turbo, the only way I would make 250hp is if I cut my boost in half.
All the big companies such as HKS and GReddy in Japan make just as many parts for the 1G as the 1JZ. There were probably 20 different turbo kits produced, three full supercharger kits I've seen first hand, internals, two stroker kits, cams, cam gears, TRD OSGiken and ORC clutches, electronics, you name it and I can get it. If all anyone wants to do is push the 7M or 1JZ that's their prerogative, but new people search these forums everyday and I'm tired of people spreading rumors and perpetuating the stereotype.
If anyone has to ask why swap to a 1G without expecting a serious answer then you wouldn't understand.
Go ahead and give them all a good woopin Project (love your white 1g)....... :rofl: :rofl:
::dead horse:: ::dead horse:: ::dead horse:: ::dead horse::
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
cool, when i looked into it i talked to godspeed, a few other people, and i couldnt find shit for the 1ggte. searched the net for it, Guess im wrong you got me.
if your mking 250hp cutting your boost in half what are you making now?
pic's of your 1g?
