MKIV rear brakes
ToySup88
33
Twin Cities
I am going to install the MKIV rear brakes on my MKIII. A couple questions to those that have done this modification:
1. The write-up on MKIIITECH says the MKIII lines work with the MKIV calipers. However, the MKIV caliper has a banjo bolt fitting while the MKIII line has a threaded-end. Does this work as claimed? How is the seal performed (without gaskets)?
2. Is there a helicoil insert that can be added to the MKIV caliper to convert the threads to the MKIII bolt size? This would eliminate having to bore out the hub.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
Brad has them. Here ya go.http://www.supramania.com/forums/showthread.php?t=97204
Search turns up some good info too.
