MKIV Front Brake Kit
CrazyHorse26
Formerly Puerto
Aug 2, 2011
110
Long Beach, CA
will the stock MKIV brake calipers and rotors fit a MKIII.......i was wondering if it would actually fit cause i have yet to try it, and i suppose it might need some slight mods to it??? anyone??​
radiod
1,342
Abbotsford, BC
It's not a direct swap over, and for the price of the MKIV hardware and the stuff you need to change so they fit, most people end up spending their money on a purpose built big brake kit. If you're looking for something to replace what you've got because they're worn out, there was a Toyota Previa that had the same front brakes on a dual piston caliper I believe...
http://www.supramania.com/forums/showthread.php?28815-Dual-Piston-Previa-Caliper
As noted in that thread though, this doesn't give you a significant advantage of more braking force, just *slightly* more clamping area and better distribution on the pad.
