MKIV Engine Mounts
bowsercake
828
Irvine, Ca
Does anyone have the original link saved? I looks like the fatter lower nipple needs to be ground down or ground off. Also, the MKIV mount does not fit into the black metal fitting that goes under the block mount bracket. The MKIV mount is as tall as the mkiii one without this bracket. Should I go without it or make it work. It is part number 12381 here http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?Figure=1107&Page=2 .
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I think the metal fitting you are referring to is the heat sheld. Since the mk4 mounts are completely shrouded in steel, you don't really need that piece anymore. Just cut off the aluminum nipple and bolt it all up.
