mkiv belt dampener?
mobes
Supras are never 'done'
Bozeman, MT
suprastanger507mgte said:
I am using a 1jz belt tensioner ( the piston/and the wheel ) on my usdm 2jzgte block. It is the same. Same bolts. same location above the crank on the left hand side.
I had to put the piston in a vice and depress it and stick a nail to keep the piston in. Nothing doing by hand...sucker won't budge. lol
So to answer your question, yes,both the 2jzgte and 1jzgte has the same location/mounting points/parts.
That's the timing belt tensioner... he's talking about the serp belt tensioner.
mobes
Bozeman, MT
Well the 1JZ cross reference says the 2JZ-GE one will work, and that's the same as the 2JZ-GTE auto, so I don't see any reason it wouldn't bolt up to the block.
How is the bottom of the shock mounted?
mobes
Bozeman, MT
I thought maybe it just mounted to the lower AC mount. After seeing these pics though it looks like there's an extra bracket.
