MKIII towing
mikeoc1
109
Ft Benning
Whats the smallest vehicle youve used to tow a supra. Last time I was able to borrow a truck. This time I may have to use my cherokee, which has the power but suprisingly weighs almost 500lbs less than a mkIII. might need to tow one 140mi. no problem?
92nsx
2,957
Clearwater, MN
I used a 4x4 s-10 to pull a sup home along with a mini van before.. You should be find as long as the truck is in good running condition.
te72
Classifieds Moderator
6,611
7
WHYoming
All depends on how fast you wanna go. I've used my Mk3 to tow my SS on a couple occasions. Wasn't particularly fast going or very far, but it gets the job done. I have no doubt that my old Miata would have been able to limp home dragging a Mk3 if need be, but it was geared to climb mountains, so...
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Is it being trailered or towroped?
I have done both, if its being trailered make sure you have adequet straps! Trailer brakes are a huge +
About 2 years ago, Going down a bumply road ~40 mile an hour, car bouncing around snapped a strap, fell off the trailer into my dads truck.
Luckily only the tailgate was damaged and it was a parts car on the way to the scrap yard:nono:
Could have been much worse.
You gotta get the big yellow straps with a 2000lb load, I used 4 or 5 500lb load straps and, well.. I always try to overkill when doing stuff like that from now on.
Sam
