Does anyone know if the MK4 tt fuel pump will work with the stock 440 injectors???
91T breezen' ROMNEY/RYAN 2012 Apr 4, 2005 1,149 0 0 NOYFB! Jul 4, 2005 #1 Does anyone know if the MK4 tt fuel pump will work with the stock 440 injectors???
C Celica Supra Banned Mar 31, 2005 241 0 0 36 Saint Paul, Minnesota Jul 4, 2005 #2 The stock fuel pump will work with the stock injector. The Mk4 fuel pump will work also.
GrimJack Administrator Dec 31, 1969 12,377 3 38 56 Richmond, BC, Canada idriders.com Jul 4, 2005 #3 Agreed. However, from what I hear, the walbro also works, is about the same cost, and flows much more.
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Jul 4, 2005 #4 Isn't it a necessity pretty much with a walbro though to remove/drill out the "J tube" restriction so the pump doesn't kind of fry itself?
GrimJack Administrator Dec 31, 1969 12,377 3 38 56 Richmond, BC, Canada idriders.com Jul 4, 2005 #5 Even if that is required, it's a 3 minute job.
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Jul 5, 2005 #6 Oh yea... I know its not difficult to do. Just making sure its known so that future problems do not arise.
W whopwood New Member Jun 27, 2005 56 0 0 58 Madison, WI Jul 5, 2005 #7 I'm running the MKIV/440 setup and it works fine. I drilled the j-tube out to be just a little bigger as the pressure was backing up on it. Also, I didn't need to upgrade the stereo to drown out the whine-bro
