Mk4 TT 17" alloys
BigSupe
97
England
Do the mk4 17" alloys fit onto the a70 chassis? Do you need spacers etc
Fronts are 8j et50mm
Rears are 9.5j et50mm
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
You don't need spacers. But, when I had them, I was recommended getting 25mm up front and 15mm in the back to make them flush. You'll have to get a quality set of spacers up front though. The ones that don't use your stock studs to bolt to the wheel.
But, it is true. You should have searched. I made a thread myself after no luck finding the answers.
BigSupe
97
England
I tried the search and found that the wheels did fit, but I meant do they fit properly and require spacers etc
Cheers
gixxer750
2jzget comingsoon!
Mississippi
perfect fit, no spacers required. you do NOT need the mk4 lug nuts either as is popular belief. The center caps fit just fine with the long mk3 lug nuts
Supracentral
10
My MKIII with MKIV TT 17" Wheels:
No spacers.
MKIII lugnuts.
Cetercaps fit fine.
P285/40/17's Rear
P245/45/17's Front
