Mk3 Supra 90 Model, Spitting codes of 34,24
Mk3Shogun
Tx
I'm currently Running 1.4 mls headgasket and arp head studs ,The turbo was upgrade it ct-26 to 57 trim. Has front mount intercooler with piping and hks bov,k&n intake, 3in full exhaust to turbo, test pipe. Its giving me Codes 34,24 (24 being Intake air Temp Sensor Signal and 34 Turbocharger Pressure) Now where can i check for both of them and get them fixed? Thank you for your help.
8,897
Replace the 57 trim with stock, that gets rid of the 34. Test the thermistor circuit for 24. And since the ground is shared E2, (clean ground), that leaves two choices for you. And one of them isn't the ECM.
Mk3Shogun
Tx
It feels like a fuel cut just hit me and then it still wants to go... the check engine light came on after that pull.
8,897
34 is abnormal turborcharger pressure. When the fuel cut happens, this comes with it. The T4 compressor wheel is the source. Now you have to work your way around it.
Mk3Shogun
Tx
Sounds like fun Nick sounds like fun.... Now to put it on lowest boost possible or go with stock, Well thanks for your help and I will come back here if anything else spits out a code.
Mk3Shogun
Tx
Do you see a cheap one around, the most i can see is 60 off of craigslist.. Or you can Pm me with one. But i'm still looking. Thanks.
Mk3Shogun
Tx
Man taking it in night fuel cut comes a little on but smooth take off, but in the evening Fuel cut 80% But from some reason when i do a 1st gear burn out it doesn't wasn't to fuel cut until 2nd gear.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
If you're hitting fuel cut at 2000 to 2200 rpm I want to know your secret. With my 57 I dont't hit full boost until about 3k. If you're serious about doing the lexus/injector job, do a lot of research first.
Mk3Shogun
Tx
Matter of fact i'll post up a vid of it, today in the afternoon. I looked into that lexus meter and injectors.... Seems like tough work.
IndigoMKII
2,181
Madison, Virginia
What psi are you hitting? Mine hits 8 psi with stock downpipe and borla catback. I'd remove anything like shims/boost controllers til you find why its hitting fuel cut so low.
Mk3Shogun
Tx
Well i just went for a ride and forgot my cellphone..... But i just got my car back from the shop and they took off the test pipe that ran underneath, The before and after of the stock downpipe and the test pipe its a bit choppy with the 2nd gear on the stock downpipe but with the test pipe its a wide powerband with no fuel cut as well. All and all the stock downpipe kills 1st and 2nd gear but 3 4 5 smooth sailing, as for shims i don't know if the owner before me put them on.. so i wouldn't know where to check for those.
8,897
I wasn't even thinking about 2200 rpm. You probably have a leak between the air flow meter and throttle body. Don't buy a new air flow meter. Until you test it and the circuit for that 24.
