mk111
carper77
sunbury
How do u put fluid in the gearbox and what do u use
91 mk111 3litre non turbo:1zhelp::1zhelp::1zhelp::1zhelp::1zhelp:
Zapp
107
Chicago
1st of all, Welcome to SM. As I see this is your 1st post I will let you know before everyone else jumps all over you. Up there near the top of the screen is a search button, it will tell you a lot.
And is an MK111 similar to an AE111 Corolla?:dunno:
92nsx
2,957
Clearwater, MN
The eaisest way to fill it is to remove the bezal/ trim around the radio, remove the shifter and fill from where the shifter came out of the transmission. Your Tranny in the N/A is a W58.
Gear oil: SAE 75W-90 or SAE 80W-90.
Total capacity for the W58 is: 2.4 QTS.
Thread end>?
j3pz
still learning
here, bookmark this. this will have every answer to a stock supra.
http://www.cygnusx1.net/Supra/techtips.aspx
thats the toyota service repair manual. according to that, the nonturbo 5speed holds 2.4L of 75W-90 or 80W-90. for an auto it says to use ATF dexron II and has a capacity of 7.2L (it says something about drain and refill 1.6L). and as a side note, it says DO NOT OVER FILL.
so there's your freebee. next time you try searching, if you cant find anything, then ask for help. and welcome to the mania
edit: 92nsx beat me.
also what i do when filling my r154 is take out the shifter, andd then use one of those screw-on-bottle pumps and hose
slowpra na-t
Permanently Banned
Oct 16, 2008
132
murrieta ca
just take out the fill plug on the side of the tranny (i think a #17 head) pump in the gear lube (75w-90) put plug back in and done.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
Thread end>?
Liters and quarts are two different things..
Sawbladz
1,727
Oshawa, ON, CA
Even if you fill from the shifter, you should still remove the filler plug. This makes it impossible to overfill. Have fun with the stinky oil.
