Friday at lunch, my car was idling really bad. I can hear a vibration/rattle type noise coming from the CPS area. I thought I had it pinned to the CPS; but, I switched it out with my spare and the noise is still there along with the miss.
I had some trouble getting it timed. I can't get it to 10*BTC with the jumper from E1 to TE1. The best I can get it to is ~13. Jumper out, ~16.
There was a code 25.
After getting it all buttoned back up and drove it around a bit, there is a noticible lack in power and idle vac is 15psi instead of the normal 17psi. Boost is pretty close to the same however.
I came back home and pulled the EFI fuse to clear the code. After that, it wouldn't idle on it's own. I had to help it. After ~4 minutes of helping it, it idles on it's own. There are no codes; but, it still misses.
Plugs: ~4k miles.
Wires: ~7k miles.
I'm sure a compression/leak down test is in order; but, aside from that has any else experienced these symptoms?
Sorry for the long post. Any ideas would be great!
Thanks everyone!
Plugs: ~4k miles.
Wires: ~7k miles.
Thanks everyone!
