The Car Misses like crazy if I try and boost past 5 psi. I hooked my MBC back up and then it will boost trying to push the motor untill I popp an IC pipe, while missing after 5 lbs still. Car has boosted @ 11psi just fine before.
LexAFM/550cc's/intake/full exaughst/NKG's ....etc
1. Is it fuel cutt?? Its not like Power--NoPower--power. Its like Rev Limiter feel.
2. Doesn't seem to be a boost/vac leak either. As MBC = Boost > 5psi
3. Is timeing being pulled due to detonation perhaps >???? TCCS ??? How to tell
4. I checked the timing and it was off ALOT ????? It did run well ??? WTF ?
So I set the timeing correctly. Jumpered, -10 deg TDC
The only codes EFI is getting is speed sensor and the occational 52 and I can feel it. Code 52 is a bad wire.
Minus the rough starting the car has good power but will not boost past 5 lbs.
I have recently replaced R154, knock sensors, wired up the front VSV looking thing with a round dial on it. Previously the rear KS was broke off for years it looks like and the frnt VSV wires were cutt and the car boosted fine, so the problem shouldn't be there.
ANY help is greatly appreciated guys.
