misfire after 20+ min drive.
88YotaTurbo
658
Wolcott, Ct.
Ok I'm experienceing a funny problem an I need all the pro help from SM. I have read as much as I can find on SM about plugs and gap etc.
My problem is a misfire/sputter which only happens after driving the car for 20 or so minutes. It happens through all rpms and at idle. It does however stop when coasting in gear.
My current setup is 12 degrees BTDC and running NGK platnium plugs. stock gap with 12-13 psi. What is your opinions guys?
88YotaTurbo
658
Wolcott, Ct.
I also forget to mention I recently swapped from turbo to n/a cams. I replaced the valve cover gasket thinking oild was leaking out. But it was not. It is clean in my valley.
SublimeSupra
Dreams of the Touge
Jan 17, 2006
170
Largo,Fl
The only thing i can think of is maybe one of the cams is off a tooth but im just shootin in the dark.The going away while coasting in gear is wierd any codes?
88YotaTurbo
658
Wolcott, Ct.
The problem is fixed.. :) It ended up not being plugs at all..... I did however change them out anyways. My number 2 cylinder injector clip wasn't attached all the way.... Silly me missed that, since I haven't touch my injectors at anytime while I owned the car. Probably A silly look over from previous owner who used to have 550cc injectors.
