So, my good friend at Toyota (you know who you are) is hopefully getting me the following parts to help me re assemble my engine after going NA-T and changing head gaskets---
new cam seals 2 of them
2 cam COVER seals
new timing belt
gasket that goes from thermostat housing to head
o ring for cam positioning sensor
o ring for dipstick
spark plug valey gasket (toyota or aftermarket item only)
new vent hose (goes from vavle cover to block, toyota item only)
thermostat housing gasket
water pipe-water pipe to back of thermostat
all EGR gaskets(3 total I think) 2 small ovals 1 large square shape (EGR cooler)
Turbo charger oil return gasket
O ring kits for injectors
ISC or Idle Speed Control Gasket
Turbo charger to manifold gasket
Flywheel Bolts
Radiator hoses
____________________________________________
Is there ANYTHING else i should get? IIRC my main seal and stuff was jsut replaced and in good condition.
So guys, what else!
2 cam COVER seals
new timing belt
o ring for dipstick
Flywheel Bolts
Radiator hoses
So guys, what else!
