..sorry no before piks, just the final product although once i get the tig welder i will be rebuilding the IC pipes with aluminum and re-routing away from the strut tower. rubs on the hood...:cry: and i have installed a zip tie to keep the bov vac line away from the turbo, before anyone complains...hahahha
See the full 3" 3000 pipe? i just hacked the restriction off and welded an 1/8th inch bead of aluminum to keep it from poping off.. then i split a chunk of Ic pipe length wise and welded it onto the end of the upper ic pipe. eliminating the need for a reducer. lots more but they are hard to photo now...
everything in my signature i did this summer... except the head gasket was done 2 yrs ago.. Im still looking for a dyno in washington seattle tacoma area?? anyways, it was fun and educational, cant wait to do the big build up... some day... ill be gathering parts slowly...
