Here is a very interesting concept that a very small number of people are trying these days, most of them having great success: Spraying water/methanol directly into the turbo to cool the air AS it is heated by the compressor wheel, making it dramatically more efficient, lowering outlet temps, and increasing mass flow and power. Some report intake air temps LOWER than ambient, which allows the user to completely remove the intercooler, and plumb the turbo outlet directly into the intake (imagine a 7M with only 1 foot if intake pipe?:biglaugh
Many cars in the past would draw gasoline misted through a carburetor directly into the turbo with no harm to the blades. IJ (Ian) did this in the past; plus I've heard that this was the stock configuration on a 1980 turbo Trans-Am.
Here are some links and quotes I've found searching the net. Discuss!
http://www.supraforums.com/forum/showpost.php?p=6846492&postcount=5
(^^^Not risky at all. I have 3 nozzles in my meth setup. One fires directly into the turbo, two larger ones pre- throttle body. NO issues what so ever. However, I use pure meth.
Go for it, your AIT temps will thank you! Ive had my IC have frost in the dead summer at night after a long pull. BTW, I am fairly confident I could get away with my boost level(40psi with an 80mm turbo) with 100 and my meth setup. I run 110 though for added peice of mind.")
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=267
http://www.alcohol-injection.com/forum/technical-questions/pre-turbo-safe-1629.html
http://www.dieselbombers.com/cummins-corner/4634-pre-turbo-water-meth.html
http://www.alcohol-injection.com/forum/diesel-engines/pre-turbo-nozzle-placement-1455.html
http://www.cumminsforum.com/forum/g...e/108850-ill-effects-pre-turbo-injection.html
