Hey guys,
This isn't about my supra, but rather my 2001 Honda Prelude SH (my DD). Not sure why there is so much distaste towards Hondas on here, but I love mine even if it has no torque .
I've been having a noise for a while now and I can't track it down. Exactly at 2500 rpms I can hear a metallic screech/squeak/rubbing kind of sound. It only happens under load (if I lift my foot off the accelerator enough to have a neutral balance it the drive train it goes away. Also if I am decelerating in gear I will hear it while the rpms pass through 2500, although not as loud). It gets worse the more load I put on the engine. I also rarely hear it anywhere except 2500 rpms on the nose.
It sounds like a bearing is going out to me (it has slowly worsened). I can't pinpoint it in the engine bay because it only happen under load while driving. I've pulled both the PS and Alt/AC belts and driven without them and the noise is still there. I don't know what else it could be other than a bearing that runs off the timing belt (like the autotensioner or water pump).
Does anyone have any ideas? Anything easy I can check before I tear into the timing belt area and try to find it?
BTW, here is a video I took:
http://www.youtube.com/watch?v=r8Rky1QGXuY
Sorry about the sound, you will need to turn your speakers up. And this is the first time I realized my iPhone won't rotate the video according to how you are holding the camera . It's not real easy to hear in the video, but you can't miss it in person.
