supradan22 said:
No matter what you do with the 7m the chances are the headgasket will break either way stock or modded the headgaskets are faulty.
this is a common misconception. it is
not the headgasket that is to blame. the problem is the low torqe figure of the stock headbolts. factory specs call for 52 ft. lbs. which is entirely too low a figure to hold the head tight enough to the block. the bolts loosen up and back out a little over time, and thats what causes blown headgaskets for the
most part. (aside from reasons such as detonation/running lean etc...)
supradan22 said:
Havent really heard much about having the block resurfaced the 7m blocks are strong but im not the right guy too answer that question.
the blocks being strong doesnt really have anything to do with resurfacing. having a good solid block doesnt mean that the RA (roughness average) will be correct for sealing a headgasket well. over time things warp, and/or get pitted. it happens, unfortunately. we deck the block to make sure its not warped, pitted, and to make sure the RA is proper for the type of headgasket we use. we machine the head because it's aluminum, and it warps much more easily than iron. (our block) and to make sure it's also the proper RA.
-shaeff
