metal headgasket
89supra884
170
chicago
well my head gasket went on my supra, and one of my friends has a hks 2.0mm mhg that he will let me have for 75 bucks. i was going to install it, but i know you are supposed to only install it after you have machined the block. but everything is in the car. i was wondering if i would be ok just making sure the block is really clean and install it and use arp head studs. thankyou
89supra884
170
chicago
what would u recommend to make it really smooth, just gasket remover and a scraper, or what else would you recommend?
A stock HG with ARP hardware if you can't have it all machined.
There's little to no chance all 3 will be in spec and a single one out = fail and the job ends up costing triple.
Sorry if this isn't what you want to hear but it's reality, a few have rolled the dice and gotten away with it but personally I don't build grenades.
89supra884
170
chicago
so my best option would be the stock hg with arp studs, maybe ill just do that then, i dont feel like having my crap blow up on me again, i just need to have it run reliably untill i get all the money to build it. thanks
Still check the block and head for flatness (specs are in the TRSM) and if all is well go for it, there's a lot more chance of success using the stock HG and ARP's if the rest is marginal in any way.
GrKBooSt
12
Chicagoo
is there a way to just deck the block w/ the pistons and everything still in there? i don't want to pull it all apart..
You "could" do it only concern I'd have would be sealing it up and then getting all of the swarf out of it and I think that would take more time than stripping the engine and doing it properly.
GrKBooSt
12
Chicagoo
alright, so i'm on a tight budget (don't mean to thread jack) but i want to save money, not being cheap cause i plan an engine build/swap next winter but i want to do a manual swap now. block is out of car anyway but bottom end is assembled. i don't want to put myself through more trouble if i tear it apart only to get new rings and bearings..
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I'll echo IJ here. If you can have both the head and block checked and surfaced (aka: machined) then run with a MHG. If you cannot have the machine work done, then an OEM with ARP hardware performs VERY well. Given that there aren't any other issues...
As far as rolling the dice...I've been rolling them for about a year. The difference is that the head only had 4k miles on it, still had a mirror finish, and all surfaces were within TSRM spec. I'm currently running an HKS 1.2mm. It's still a gamble even at that...
GrKBooSt: If the block is out, just replace the bearings. It's not hard nor all that expensive. Even on a tight budget. Driftmotion sells a full bearing kit for like $60.
I'm in the middle of the very same thing right now actually. :)
I'll add one more thing: BHG = Rod Knock. Therefore, BHG = New Bearings.
oldsking
789
Chapel Hill, NC
If you can have the block and head resurfaced you are good just like Kenny said, WIth the 2mm HG you will be lower compression which equals more boost (With the right tune of course) If you blow the MHG then you can cause serious problems of warping which is not good for the block or head.
GrKBooSt
12
Chicagoo
i decided it best i just clean out the block fully and make it brand new. for now i may just run a "stock" setup. ill make my own build thread soon..
depends on how much has been removed from head/block previously and if/when he machines it. stock is 1.37 compressed so maybe just slightly lower but there is know way to tell just looking at it.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
what ever you do don't lower the compression. the rebuilt block in my car has a 2mm hg with .024" removed. ran it at the last autocross of the year. off boost power sucks. my previous motor had a shaved head with stock hg and arp bolts. the torque on that engine was amazing. it would dam near burn the tires off idle. lol.
it was a great autocross engine.
i'm pulling that motor and so i can lower it for this season of autocross.
gl.
