My machine shop guy told me the block was shaved off 7thousandths and the head was shaved off 12thousnadths... he saying he doesnt know the stock thickness of the stock hg.. What size MHG should i get could any1 help me thanks guys!
bwest said:1. measure piston deck height
2. head thickness (or CC the head)
3. measure piston dish volume (changes by piston brand and size)
4. engine bore = 83.5
and use a handy online calc to figure out your desired comp ratio w/ HG thickness and bore as your variable.
Stock thickness is 1.37mm compressed (.054")
bowsercake said:How much can your compression change if you run a new oem headgasket on a resurfaced head?
