I just had one of my Spal electric fans fail on me at the PNW meet this past weekend. I have a feeling its been going bad from a bit now as the car is running hot even on the hwy.
My setup now is a Koyo rad, 2jz-gte, I need to know what mechanical fan will work with this and keep it cool. I have herd that I can use the MKIV clutch and some Lexus SC fan. I still have my twin AC fans so I can have those set to come on as a back up.
The main things I need to know now are what clutch and fan blade is needed. I can shorten my upper coolant neck to allow more room for the fan blades. I would rather do that than run the risk of the fan hitting the rad.
I'm also going to duct the underside of the car and sides to allow all the air to get to the rad.
