MBC Location?
Status
Not open for further replies.
redmkiii
Bluemkiii's Big brother
Mar 9, 2006
115
arizona
I just got a MBC in yesterday and I was wondering were you guys mounted your boost controllers(pics would be nice) thanks.
americanjebus
Mr. Evergreen
wa.
just keep the vac lines you use at arround 6 inches or less.
that really limits where you can mount your MBC, im assuming you know where to tap the line in this pic, i just zip tied my mbc to the ac lines that on the car just underneath where this picture cuts off.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
yeah like americanjebus said keep the lines short...i also zip tied my mbc by the a/c lines.... by the way what mbc did u get?
souprat
fairfax VA
i have mine on the shock tower, i guess on the ac lines. made alittle "L" bracket for it and zip tied the mbc to the bracket. makes it a pain to adjust when th motor is hot and you burn your hand on the turbo.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I'm guessing this same rule applies for electronic boost controllers? IDK, but I'll be installing a MAFT Pro in the future along with all of it's components. I've seen supras with the boost controllers mounted by the passenger side strut tower, so that's def too long correct?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Lol, keep an eye on that zip tie cuz it's close to some serious heat. That would suck if that came loose and fell down, then melted the vacume hose going to the waste gate *shivers*.
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
Um....six inches or less? They guy I bought my car from plumbed the mbc into the interior, I've left it that way.......is this bad?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
if youre not getting boost spikes then leave it! if it aint broke dont fix it!
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i have mine with about a foot of vac line in both directions, i have it mounted just to the right of the pass strut. next too the fuel pump relay.
i also have a cab cable so i can adjust on the fly.
Boostedstr8six
I have better SA than you
Near Columbia, the river
It doesn't have to be six inches or less. Just keep the lines as short as practical. I've had an MBC and my current EBC solenoid attached to the AFM bracket with no issues over the past five years. Probably about 12" of line each way. Also, MBCs have at least a slight tendency to cause boost spikes.
Status
