Well you can go mechanical or electric on the boost gauge and MBC. Mechanical is cheaper and sounds like would be a good start for you across the board. Search to find out the differences.
Then do a search on wastegate signal/reference/install procedures and you'll find tons of ways to tap into things properly so you don't damage your turbo/engine.
In the end it's quite easy.
