Nick M said:Mass air flow is more accurate. Speed density is calculated , as already noted. Mass air flow, in a land slide, for daily drivers that can run 10's.
Speed density is a good choice in stand alone though, or racing. When known quantities are used and expected, not daily driving in bad weather.
Boss302 said:??? i kinda get it whats this about pressure?
Boss302 said:whats the maft pro's website? and if i have a AEM EMS i wouldn't need a maft right?
Yep. Most really fast fuelies run speed density. Less restriction. It just doesnt compensate on its own for changes.lagged said:but if temperature and pressure is known, wouldnt the calculations based off that still be correct?
