How do you know when your map sensor is bad? Even more, what or how does the car perform when the map sensor is bad? Also I got my motor in a non clip form. Where is the Map sensor suppose to be mounted at anyway?
I finally got my car running but I have a choking rpm problem. It only happens when you first his the throttle at ANY RPM. I thought it was the TPS but if it was happening at any RPM even past 4K then no way it could be the TPS right?
Lastly is the hose coming off the Map sensor suppose to plug here? It looks weird.
