map ecu?
drewmiller5007
taylorsville, NC
what do you guys think about the map ecu? any experience out there, ive heard really good things and bad things what are the pros and cons? i ran across a really good deal for map ecu system to replace my VPC.
ml43
69
HI
I've been running a Map Ecu for a couple years now. Only problem I've come across that really bothers me is when your RPM's drop below idle, it takes a little longer for the IACV to correct. My other friend running a Map Ecu has no problems what so ever though.
I made 340whp with it(ct26 57 trim), my friend made 389whp with one(boss to4e). I'd say if you are keeping it under 15-18psi, and 400-450whp, it's a good choice. Super easy to install/remove.
If you are aiming for more power, I'd suggest a standalone, so you can tune ignition timing.
