I've had little luck with map ecu on my 7m but since i've started to mess with my 1jz sc i've considered it as oppose to safc 2 but im wondering if you guys have had luck with the map ecu on the 1j.
My aim isn't high with the set up so im thinking a simple piggy back will suffice. The car at the moment is running really rich and would like to be able to lean it out just a tad so that i can actually see something a bit better than 10.0 afr's under boost.
Either way if you have any USEFUL information please provide it.
Thanks,
-emp
Thanks,
-emp
