map ecu install pics :)
TRD91whtMK3
Whitey
Oct 22, 2005
11
Englewood, CO
just finished the map ecu installation a couple weeks ago and i decided to snap a couple pics :)
tell me what you think.
TRD91whtMK3
Whitey
Oct 22, 2005
11
Englewood, CO
supradan22 said:
Very clean exactly what I had planed for mine are you running the IAT sensor that came with the kit?
thanks but no, i'm not using the IAT yet, still in the autolearning phase until i get some time to do it :)
but there's a lot of cutting involved in doing this...
first you have to make a mount for it on the stock ecu, cut the upper plastic piece so the ecu can fit through, cut 2 holes for the harness and the vacuum hose and the worst part, cut the back part of the glovebox itself so it will close with the ecu up there, then you have to cut off the left stopper to get it to close with the harness and remount it further down the side of the glovebox... definitely took me awhile
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Where can I find out more info on this product? I have seen lots on MAFT, MAFT PRO and Stinger. I keep seeing people talk about these but can't seem to find any real info.
thanks
Supracentral
10
http://www.mapecu.com/
I used to sell quite a few of them.
If you have specific questions just ask.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Is this product as good as MAFT PRO if you just want speed denisty? I know the MAFT PRO can do more then this unless you go with MAP ECU2. if you go with the new product looks like they can do most of the same things.
One benefit I see is there are plug and play harness for both of the MAP ECU's which is nice because wiring is what scares people the most.
Does either MAP ECU's allow you to plug in a Wideband to them like the MAFT systems? Or would you need to run the separate?
williamb82
906
4
Tampa, Fl.
i like it too, problem is if some deuschbag breaks into the car, then they will see it and try and rip it out. thats why i like to hide everything.
tte
Breaking In - in progress
Northern California
Hmmmm...Looks good
I was also thinking of trying out the MAp ECU...
Its made in Australia for Powerhouse racing...
Cheers,
Roy
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
very nice install, looks really clean.
Ive got a map ecu for sale, if anyone wants more info let me know, i used it on my 7m for 3 months and its in perfect condition. 330$ Shipped.
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
the stinger is a standalone... so it is just better all around, ive never played with the maft-pro but i would say it is probably more user friendly.
TRD91whtMK3
Whitey
Oct 22, 2005
11
Englewood, CO
owning a nicer-looking supra, i pretty much assume if they want something, they'll break in either way... plus good f-in luck getting that thing outta there, its rock solid :) oh and 5% tint usually keeps people from looking in... got me outta a broken window more than once.
Cya
628
Columbia, S.C>
I've heard about problems with this product, such as the car not wanting to start and loosing the tune. How true are these statments, I have one and am currently running the SAFC/MAFT and trying to debate between the two setups.
