map ecu 2.... timing and anti lag?
Tun_x
Built to do the NASTY!!
Utah
It looks like it is about the same as the maft Pro.. It says you can use an external sensor witch is an improvment but I doubt it can run the mk3s multiplexing igntion . If it can I wonder if it can give a total timing value or if it will only give you what it is adding or taking away .. It is still a piggyback!!
Where did you see antilag .. I see somthing called Launch control wich probably consist of a simple 2-step
P.S. Steve is gay
MKIIINA
Destroyer of Turbos
Plano, TX
it does have a 2 step program built into it but past that i hadnt heard about any antilag just yet. yes its a piggyback but it can be powerful and since this is version 2 hopefully it will be be a little easier to use over all and fix some of the older issues.
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
Tun_x said:
P.S. Steve is gay
....Hater
it does sound a ton better than the first, will but i would have to play around with it to decide its worthiness. and dont worry mr. hater my next management is still going to be a standalone:icon_bigg
dejacky
175
"taxus"
Map-ECU I & II are both CRAP-ECU's for karmen vortex cars. So if you're not using a karmen-vortex ecu, you'll have better results with the map-ecu.
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
please elaborate........ what is the difference between the map-ecu, maft-pro, and VPC as far as the way they convert? it seems everyone with a MKIV and a map ecu loves it but of course that is AFM.
