hey guys, my PS sucks, i have removed the res, and pump was was told that driving a PS rack with no ps is bad, so i want to go manual. are there any options for the mk3 out there. ive search or tried to search and have come up empty...
the link really didnt do anything but show off the childish behavior of some members. the write up on the rx method was ok, anyone with the mustang way?
I looked into doing it for my MK2, realized it'd be more of a PITA to go manual than fix the leaky rack. I think the main reason people say it's bad to run a power rack manually is bc of the gearing. it's not geared for "manual". and I'm sure you'll wanna make sure the rack has Lubricant in it, so if you sealed it up good.. ie clossed off the ports and such... it would work. I'd just keep the power. what's it worht? 5HP under full steering? in a straight line I bet the HP loss is less than 2HP b/c there's no real load being put on the pump/belt/engine.
I never liked PS in mine...especially since it wasn't progressive. I would barely touch the wheel on the freeway and just about loose it, it's a PITA to try and not overcorrect with it. Plus I don't do drifting anyway, and it's good for the forearms!
