Malloynx BOSS-550 Turbo!!
PorterzSupra
703
Hebron CT
Nice vid BTW!! What is he running for turbo size? What's the COLD and HOT numbers on the housing? cuz it appears to be very large.
gixxer750
2jzget comingsoon!
Mississippi
go to hpfreaks.com and go to turbos. Look up the boss 550, that will give you your answer ;) I don't know the specifics of it, but I believe he is running the big shaft Dual BB version.
PorterzSupra
703
Hebron CT
I looked on hpfreaks could not find it, still no specs on the allmighty "boss 550" turbo. If Mike sees this can he please tell us the HOT & COLD side trim and also the housing A/R because it appears to be huge and im very curious!! THANKS!!!!
PorterzSupra
703
Hebron CT
THX, looks like housing is .83 A/R , compressor wheels range in trim size from 50 up to a 74. It does not tell what the turbine wheel sizes are
malloynx
NC
Let me dig up the specs.. i know it's a 67mm dual ball bearing; big shaft option with the ITS GTS cover..
this thing flows :)
btw.. i will have 30psi runs this weekend.. this will be intresting..
malloynx
NC
IJ, when i first put the turbo on i was having surge. Now that i run 2 bov's the problem is solved.
PorterzSupra
703
Hebron CT
On the dyno is seems to lag for a second before the engine comes to life lol, anyway you are pretty popular on here now, did u ever find all the specs im very interested.
