making a 7mgte from a 7mge
JibithofJib
Street Racer
Apr 30, 2006
8
California
I have a non turbo 89 supra, and was wanted to get a 7mgte engine. im not much of a skilled mechanic, and was wondering a few things.:1zhelp:
1- can i buy the turbo parts and put them on my 7MGE to practically make it a 7MGTE
2 - ive found a few 7MGTE engines online, could i take my 7MGE engine out and put that one in? would i have complications? would it even physically fit?
3 - or would i be better off just putting aftermarket turbo parts on my 7MGE. (i would just do this, but most turbo parts i find were made for the 7mgte)
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
the motors are the same with the exceptions of the intake cam, the compression ratio None turbo is i believe 9.4:1? and the turbo is 8.5:1? also the wiring harnesses are different there are two knock sensors on the turbo block and only one on the N/A block. the turbo block has oil squirters and the N/A doesn't. and then you would need a turbo ecu so it can read that there is boost. the turbo motor goes right in. so for the most part they are the same motor with a few minor things that are different.
Guys please corect me if im wrong but i think i got everything.
Good luck man
