supra90turbo;1410988 said:The doors themselves are quite solid, but I know what you mean. It makes a hollow "bung" type sound or the regulator and rods rattle when you close it.
If it really concerns you, take the door panel out, take your sockets and go crazy. You'd be surprised as to how many loose bolts you find in there, and there's some stuff you'll have to adjust back to spec. There's probably a few broken lock rod guides in there. New felt window guides do help as well.
These cars ARE like 20 years old, remember
ValgeKotkas;1411004 said:That's the door stopper clicking. The 3rd ''hinge'' in the middle with the handle that moves.
At least I think so.
deabionni;1411008 said:Don't forget to look at the door's hinge pins. On a 20 year old car, I could almost guarantee that they're worn an need replaced.
If they're worn, they'll let the door drop slightly when it opens; and it'll defiantly make more noise when you close it. On my car, the passenger door closes like a new car; but my driver's door drops a slight amount when I open it, and makes noise when I close it. Once I replace the hinge pin on my driver's door, it'll close like new again.
Alec;1411005 said:Is it supposed to click? I've tried some WD-40 with no luck.
