i changed my headlights now they wont work but they will still come up and go down i took a light tester and tested all the fuses under the hood and they all lit up except the fuses for the head lights what can it be
jza70mk3 said:i changed my headlights now they wont work but they will still come up and go down i took a light tester and tested all the fuses under the hood and they all lit up except the fuses for the head lights what can it be
i did a motor swap as well but it worked even after untill i changed the lightsdirtlord420 said:i got the same problem. but mine happend when i switched engins.
bluemax said:Oh....dumb question, but I need to ask.
When you tested the power to the head light fuses, you did have the head light switch on and the head lights were up? Right?
And you do have the bulbs in the receptacles all the way. If they are not making good contact, the bulbs won't work and you won't get ground to the head light fuses and your light tester will not light up if you're using the power and ground at the fuse terminals.
Does the high beam indicator light on the instrument panel light up when the high beam is switched on?
Try a volt meter at the head light fuse and ground the other end to the chasis or battery.
