i got rod knock on my block and im going to be replacing the main bearings is there anything that i have to do before i put the new main bearings in and also should i get an oversized bearing or just replace my fried bearings with stock size main bearings?
aslo what do you think about King engine bearings?
FAR EXCEDS FACTORY SPECS
1400 DEGREE MAIN BEARINGS, MUCH GREATER THAN FACTORY 400 DEGREE UNITS
FORMULA 1 RACING USED AND TESTED FOR OVER 40 YEARS
NEW TRI-METAL SMELTING PROCESS FORMS A MUCH MORE UNIFORM BEARING
REDUCES ROTATING FRICTION AND INCREASES HORSEPOWER
SILICON COATED TO WEAR LOW SPOTS AND FILL HIGH SPOTS, MAKES FOR A MUCH BETTER MATING SURFACE AND EXTENDS ENGINE LIFE.
FITS TOYOTA 7MGTE MOTORS FROM 87-92
AVALABLE IN STD, .25 .50 AND .75MM OVERSIZED.
